FP3 losing battery much more quickly
My wife and daughter both use a FP3. First my wife experienced that she had to recharge her FP a lot more often than usual. A full charge would usually last 2-3 days. Now she needs to recharge every day. I installed Accu Battery and used the inbuilt manager but I can’t identify an app that is responsible for the drain.
I also did check for a bloated battery, but everything seems fine.
My wife did not install a new app, but she did install the last system update. Around that time the problems started to occur.
My daughter naturally uses more apps, but her problems also started after installing the last update.
Anyone with similar experiences?
Thank you!
If this is related to the last update suffixed 0016.6 it may be more noticable in that topic.
