FP3 locked with critical unlocked
I have a case of Schrödingers lock on my Fairphone 3+. I have unlocked the bootloader some years ago to reinstall Fairphone OS. I did lock the bootloader afterwards. On Fastboot the device is marked as locked. Things like Google Pay do work. When I executed the command: fastboot oem device-info
it shows:
  • Device unlocked: false
  • Device critical unlocked: true
I think I forgot a step when locking again. Now I do not know if it is locked completely. I guess not. In this state, is it possible to modify the critical partitions? Or with other words, how insecure is the phone now?
If Google Pay works and you don’t see the obnoxious bootloader unlocked warning-screen on boot, I am pretty sure your bootloader is locked fine.
