I’m not using often my front camera. But yesterday I had to find out that capturing a selfie is not working any more. Though I can see the preview. But when I make a selfie, the result is a completely green picture.
I’m using LOS18.1 (latest official built).
I did try different camera apps. My top-module works in a different FP3. In my FP3+ an old FP3 top-module works. A different FP3+ modules has the same effect.
Anyone else facing this problem?
Couple of weeks ago it did work. Thanks in advance.
PS For the moment I’m using the 8MP FP3 top-module.
Therefore I think too, it is a problem with one of the latest LOS 18.1 builds. In the LOS Thread I did check the last couple of weeks, but couldn’t find this problem.
I think the discussion is better in this thread, then in a thread with 358 postings right now.
But maybe I ask in this thread and link to this.
I did ask a colleague with a FP3+ running LOS18.1. Same problem.
Interesting using signal to make a selfie within signal messenger it works. Using a camera app will result in a green picture.
I understand your intention but would not completely agree, as I dont know how Frequent the developer check the forum for spreaded topics around LOS issues, so I would def advise to put at least a note to the LOS topic. I know there have been at least some unofficial builds with new Kernels recently not sure if this was moved to official or LOS 19 unoffical or if this could have any effect. However in the past there have been issues with green tinted Selfies under Stock OS
So as/if this is casued by the latest LOS build and there is no workaround to use other Apps like open camera, you have to wait for the LOS developer to fix this.
I have confirmed the issue on my test phone. I am using the latest LineageOS build from 04.04.2022 and an FP3+. Interestingly enough, the video preview through the front camera works fine, only taking a picture is broken.
This may be related to https://gitlab.com/LineageOS/issues/android/-/issues/4536.
Thanks for reporting, will keep you guys posted with progress.
I could not identify any specific recent change that might have broken the built-in camera app. Alternative apps like OpenCamera appear to work fine. Since LineageOS 18.1 is going to be phased out soon I will not be able to spend more time on this topic, unfortunately.
Unfortunately no : I tried to take a picture today, after a long long time, with OpenCamera.
And surprise : the app freeze and then “serious camera error” is reported on the screen.
This happen with both front and back cameras.
I used the latest build (lineage-18.1-20220418-nightly-FP3-signed.zip).
Woh, already replaced ? O.ô
It has not lasted even a year.
Well, I guess that’s also good news since it means we can have a more recent android kernel.
