Hi All,
Just wanted to know if there is a way to show the internet speed in the top bar as in other phone… couldn’t find it…
Thanks in advance for your help
M
Hi All,
M
thanks and sorry for the stupid question …
It’s not a stupid question.
Some Android OSes have this built in as you apparently have experienced before, and some haven’t. The versatility of Android is a strength as well as a weakness.
LineageOS (a custom Android OS on many phones) for example has this as a setting in the OS, Fairphone OS (the stock OS on the Fairphone 3) hasn’t.
If you go for an App, make sure it doesn’t try to get permissions it doesn’t need to have for this minor task (e.g. it wouldn’t need access to your contacts).
