In the worst case: There are left hand drills available. If try a ânormalâ right hand drill, you may damage the thread in the display.
Thanks for the replies. Iâve tried the âeasyâ fixes, the screw wonât move and I donât have a left hand drill on hand.
Tbh I donât want to damage the screw any further, so I think Iâll take it to a repair shop (sadly)
Iâll keep you posted!
Hey,
So changing the bottom module didnt help.
I guess I should follow @FPbonnâs advice and try to clean the mainboard with IPA.
Is there any way I can try to backup the data beforehand?
To summarise the situation:
My FP3 wonât charge and therefore wonât boot, the battery drained quickly before I could do a full backup. The bottom module was changed and that didnt help. I also got a brand new charger.
I still have an old battery lying around but I wanna keep it as a last resortâŚ
Iâm wondering if itâs possible to change the mainboard (if I buy a second-hand FP3 or 3+)⌠Has anyone tried it?
Wouldnât it be easier to use the second-hand phone as it is? The mainboard is basically the phone itself, at least the biggest and most expensive part.
