FP3 Display freezes! Display noise issue
Same for me - and thanks for the suggestion! :grinning: My FP3 had worked for years without problems (in contrast to the previous FP2, which had suffered from the Random-Reboot-bug). Then I decided to upgrade the camera module. Swapping the module itself was no big issue, but afterwards, I got either:
  • a rainbow pixel screen (with losely tightened screws),
  • a black screen (for really tightenend screws).
    (In both cases, the phone still reacted to switching it on.) Dis- and reassambling, twisting etc. did not help, but cleaning the golden contacts with isopropanol (from a well-equipped pharmacy) and a cotton bud removed the problem. Fortunately, the phone is fine again.
I had the same issues with a newly bought screen. Reassembling the screen did not work (actually it made it worse). Even loosening the screws or tightening the screws. Usually, a hard press or a twisting of the phone fixed it. But only temporarily.
What fixed it for me, was to take some very fine sand-paper and gently applying it to the pogo-sticks and the contacts. I assume that some oxidation layer had formed on the contacts or pogo sticks which made the connection flaky. It has been working for a few days now with no issues (even after i dropped the phone on a tiled floor).
Hello all.
I bought a FP3+ off ebay with a known display issue (noise, coloured lines, etc.), but in otherwise perfect condition. Cleaning it up the contacts didn’t help at all so I bought a new display module. The bootloader warning and fairphone splash work fine but as soon as Android starts loading I end up with the display freezing/super-slow and/or noise issue. I’ve tried most of the suggestions on here (including some of the more dubious, which for all I know made things worse).
The odd thing is it seems to be most reliable if I don’t put any of the screws in - if I do it is a seemingly random loosening and tightening that will find a sweet spot that lasts at most an hour, or immediately stop working if I put the back cover on. If I leave the screws off I can put the back cover on and the “twisting” technique to fix the phone seems to work (which isn’t the case with the screws in).
My suspicion based on the above is a short circuit of some sort rather than a loose connection, but I’m perhaps grasping at straws.
Does anybody have any suggestions? Sadly so far this phone is proving less reliable than the one it is replacing (and that is saying something).
Hi, even if this topic is already a bit older, maybe someone may find this info useful. I also suffered from noisy display problem. I disassmebled the screen, cleaned everything but no luck. Then I checked the golden solder pads and found that they were damaged as shown here:
The holes are caused by the needle contacts from the main board. So I tried to put a bit solder on very pad, but that didn’t helped. In an act of fustration, I ordered a new display module and installed it. To my surprise this also wasn’t the solution to the puzzle! But now I have a display in spare :slight_smile:
So the problem must be on the mainboard side. I should have seen this at the first glance, oh my…
One of the sping needles was stuck so it never could reach its golden pad counterpart. I used a small needle to pull the other small needle up and checked that it bounces well (like I did for all other spring needles).
I put everything together again and - tara - it worked again. So I hope someone will find this usefull - hello support???
Hi everyone,
I’ve had a FP3 for almost 4 years now.
About a month ago I had this rainbow noise & randomly stuck display problem after launching the last Android update. It settled 24hrs after the update was completed and I cleaned up some of the storage. I thought it was a software problem.
And suddenly the same thing happened yesterday, only worse. The phone displays noise by default, is very long to react to my commands if at all.
Trouble is I’m on vacation and I didn’t take the miniature screwdriver with me so I cannot try to disasemble it of check the screws. Do you know if it’s possible to use another tool ?
Any Phillips #00 screwdriver should do.
Hi folks,
I might had a similar issue as you can see on this screenshot.
I did the following to solve this issue.
  • Disassemble the display using this guide.
  • Clean the phone with a brush and the display contact pins using alcohol.
  • Reassemble the phone following the guide above in reverse order.
I hope this helps. Cheers!
