I can not find in the info, if the default OS that will be installed when I continue to do the first start setup, is the Google free Android, as mentioned here
https://support.fairphone.com/hc/en-us/articles/9979154556817
thnx,
Cor
thnx,
Cor
You can buy it preinstalled from Murena, however else FPOS comes with Google and you would have to manually install another OS, after the initial setup
Ah, so the FairphoneOS
✏ Operating Systems for Fairphones
is not only based on Android, but also still includes Google services (…)?!
Then, I think it is very confusing to read " Google-free Android" on this page
that links to
Open Source and Fairphone, what we believe in - Fairphone
that links to
https://support.fairphone.com/hc/en-us/articles/360048657752-Open-Source-Android-OS-for-FP3-FP3-
that links again to
Yes Fairphone uses the Open Source Android [ASOP] as a base and then incorporate standard Google services and apps for the common user that wants an easy to use phone that can be updated over the air.
Murena are more fussy and don’t use Google service etc. but there is a connection
The links are only a direction the the de-googled idea
What are you looking for?
Hmmm, they talk about Google Free Android and not Google Free Fairphone OS, so I guess the articles are fine and clearly state that FP Open OS was only for the FP2…
Reg “Google free” some discussions
No, it is not. By default a FP3 has Fairphone OS (FPOS for short), which is a pretty close to stock Android including Google services.
Best wishes,
Thomas
