FP3 : Bluetooth music interruptions
When listening to music with a Bluetooth device (headset or other), there are micro-interruptions every 10 to 15 seconds, which makes listening very unpleasant.
I bought my Fairphone3 about 4 months ago and I am again obliged to buy another “standard” smartphone because of this problem (already had problems with the FP2), does ecology necessarily have to rhyme with poor quality?
Note: All softwares are up to date, problem only on the Fairphone itself.
Where is the music coming from?
Is it possible to use another app?
As you had it already with your FP2 could it be a problem with your bluetooth device?
Music is coming from standard app (Google Music, Youtube music, etc…) these app works well on other smartphones. The problem appear on ALL apps, the problem is not in the apps.
And problem appear with any device (headset, speaker, car, etc…) .
Again, problem is on FP3 only !!!
I have a similar problem. I use JBL LIVE Pro2 earbuds with bluetooth 5.3 on my Fairphone 3 with bluetooth 5.0 and the interruptions are annoying.
The ‘specialists’ in the shop want to sell me an iPhone or different buds, but I like the phone and the buds.
Is there a way around this?
I also have this problem with FP3+ mostly listening to AntennaPod app.
I noticed when I move the phone to my right hand side (where I have the Fairbuds XL speaker that has the controls) or to my front, the interruptions stop. When I move the phone to my left hand side or to a pocket in the back of my pants, the interruptions increase.
Was wondering whether replacing the phone part that contains the BT hardware might fix the issue. Headset works fine with my HP Windows and Framework Fedora laptops, I can wander far away from the laptop and only after a few metres I get interruptions.
