Hi there,
this topic could be interesting to you, if
- you have a FP3
- use LineageOS 17.1
- you have to install every update manually because the Updater software does not work
I hope there are some folks out there who find it useful. The message in short is: You can install the copy partition without factory reset following the instructions on the lineageos wiki…
Solving this issue is as simple as this:
Prerequisites:
- Go to the LineageOS installation instructions: Install LineageOS on FP3 | LineageOS Wiki
- Download the copy partition zip file hidde in the here: Download the
copy-partitions-20210323_1922.zipfile from [here]
Procedure:
- Restart FP3 into recovery mode
- Connect FP3 to computer
- Press APPLY UPDATE on FP3, then APPLY FROM ADB (if you get error messages, go back into main menu / advanced → press ENABLE ADB
- on the computer, initiate adb sideload xyz.zip
- restart FP3 into system
- DONE!
All the best, Jens
