Fp3 update android 13 does not recognize Sandisk extreme pro 64GB. What can I do.
Do you get an offer to format (means delete!) the SD card? Can you put the SD card into the PC and try a filesystem check?
Jens1, Thank you for your answer. On my PC I see several maps. The most are empty. The configuration of SD-card is the same as android. I think the best way is to format de SD card. Must I format the SD-card in FAT?
I would recommend:
- exfat
- always use the device for formating in which you want to use the SD card
The problem is foggy but now resolved. I took out the battery and SD card. Installed again after half an hour. Problem solved
