If I had to put money on a bet, I’d say no, probably not going to happen anytime soon, given the list of known issues there’s likely harder bits to chew first…
Certainly was not addresed in the past 3 updates…
Not giving up hope either, though
Hi all,
Since le latest OS update (I think), I cannot get anymore notifications on the lock screen of my FP3. Just the padlock symbol. Any idea ? I have checked that they are allowed in the appropriate menue.
(Notifications have neveu worked well anyway…)
Thanks !!!
Hi AurelienB,
I moved your question here, it’s the same thing. But there is no solution (yet).
Thanks Ingo. Indeed I have the same problem
Hi all, I switched from FP2 to FP3 early January and was absolutely stunned and super annoyed that my alarms doen’t show on my lockscreen anymore. When I set a timer, and it goes off, I have to unlock my screen, go to the app, and thén turn it off. With my morning alarm, it goes off, but instead of the usual screen showing options to snooze or dismiss, I have to enable my screen (this keeps it locked though, so there’d at least a different signal), then toggle the active alarm notification and then turn it off. This is the opposite of convenient to me and I’ve tried seemingly everything when it comed to chaning settings.
It seems my phone categoriezes alarmd as silent notifications, which seems ridiculous. Can I change this?
Hi Anais,
for me the morning alarm on my FP3 with Android 10 works just as expected, i.e. I get the usual turn off/snooze options without having to unlock.
Just checked the notification settings for the clock app and I have enabled all categories.
Not sure if that helps, though, in case your settings look the same.
Did yo try setting an alarm and when it “goes off the wrong way” change the settings of the active notification? On top of my head I don’t know of a different way to change a notification between silent and normal (if that’s the cause of the behaviour).
I usually just have a swipe for my lock screen and never had a problem, so since your post I have enabled a 6 digit pin number to see what would happen.
The alarm went off and there was a button center of screen that I could swipe to disable, I wasn’t required to unlock.
This is FP3+ with A10 0077 update
