Hi everybody,
how do I activate USB-debugging on a FP3. The usual manuals say tap 7x on buildnumber to activate developer-mode then activate usb-debugging.
I was able to activate developer-mode but now I can’t find the option activate usb-debugging. The FP3 has Android 10. Is this option hided somewhere else?
You can search for “debugging” in the settings app and it will find the relevant entry in the developer options. It’s right where it’s supposed to be and called “USB-Debugging”.
