Hi Community. I dropped my fairphone 2 on the ground and now the screen is all black…Has any of you tried the same?And do you know how to fix it?
I asked two different phone repair shops here and since they don’t know the brand they cannot help me.
Hope you can!
//Valinka
If you’re lucky, only the connection got loose. Try to disassemble and reassemble the display unit, maybe it helps.
Hi!
Thank you so much for your advice!
It worked!
I just needed to open it and put back a small cable that was loose.
(I couldn’t disassemble the screen myself, so had someone to help me though). But now it works perfectly again.
Thanks!
