My FP2 ( a few months old) will not turn on. When I press the power button or connect it to a charger, it only starts to vibrate, and will not stop before I remove the battery. Is there anything I can do to fix this?
Unfortunately I have no solution but a similar problem, though I have more problems if I turned it off myself, I have to press the on button for up to 20, 30 seconds until the ‘turn it off’ button appears…
