FP2 Open OS 16.05.0 Temperature Issue
After I have updated my FP2 (Open OS) to version 16.05.0 my phone is very hot all the time. Calling someone is not enjoyable anymore since it’s getting hotter while calling. The area above/beneath the mainboard is affected. Has someone else the same problem?
I don’t believe this is a general issue with the update but since it happened afterwards maybe something went wrong, so try to run the update again manually.
Another thing you could try is take out the SIM(s) to see if it’s somehow related to them.
I think you’re right. I updated all my apps and the problem seems to be solved. I will update this thread though.
