hat jemand Erfahrungen mit “Abdeckungen” für die Kameras des FP2 (Spionageabwehr) ? Danke !
does anyone have experience with “covers” for the cameras of the FP2 (counterintelligence) ? Thanks !
quelqu’un a-t-il déjà utilisé des “couvertures” pour les caméras du FP2 (contre-espionnage) ? Merci !
For the front-facing camera, you can get a sliding webcam cover like this one on eBay. The seller provides the exact dimensions of the cover, and according to my measurements, it fits the FP2 nicely.
As for the main camera, I’m not sure how you’d cover that. Maybe something 3D printed?
Maybe glue a cap off a juice carton to the back cover, over the camera? It’d look a bit ridiculous and I don’t know if you could find one that fits, but it does seem like it would work.
