If I use GPS functions the FP2 gets very hot. The battery drains: form 100% to empty within 5 minutes. Even if connect to a charger, the battery drains and switches of.
A hot phone does not charge efficiently. So that makes it worse.
Can the GPS unit cab be replaced or is there another way to repair this.
This issue is already for 2 years. I am fed up now.
That is bizarre and it sounds like a hardware problem. You say this has been an issue for two years - have you contacted Fairphone about it? If youâre within warranty, they can help you troubleshoot and replace parts if necessary.
If youâre out of warranty, Iâd try a factory reset to begin with - unless youâve already tried that, of course.
A factory reset will surely delete your data, itâs a feature of the reset.
But you can lose your data because of a hardware defect in any given next moment. With any computer tech.
Thatâs what you should be afraid of, and thatâs why you make regular backups of all your important data (no backup = no important data).
You can also wait to see if anyone else has any suggestions, but I really am afraid a factory reset is the best option. If you do contact Fairphone this is probably the first thing theyâll ask you to do.
Troubleshooting Android phones often goes like âtry one or two little fixes, and if that doesnât work just factory reset the whole damned deviceâ - a sorry state of affairs, but it is what it is.
