FP2: Fairphone OS & Fairphone Open 22.12.0-rel.0
Fairphone OS & Fairphone Open 22.12.0-rel.0 are now available. You can get them through the Updater.
Changelog
Issues fixed since the previous Android 10 release (22.10.0-rel.0).
  • 2022-12-05 security patch level
    • from the Android Security Bulletin—November 2022:
      CVE-2022-20414, CVE-2022-20426, CVE-2022-20441, CVE-2022-20445, CVE-2022-20446, CVE-2022-20448, CVE-2022-20450, CVE-2022-20451, CVE-2022-20453, CVE-2022-20454, CVE-2022-20463, CVE-2022-20465, CVE-2022-2209
    • from the Android Security Bulletin—December 2022:
      CVE-2021-0934, CVE-2022-20124, CVE-2022-20131, CVE-2022-20144, CVE-2022-20411, CVE-2022-20442, CVE-2022-20449, CVE-2022-20466, CVE-2022-20468, CVE-2022-20469, CVE-2022-20470, CVE-2022-20472, CVE-2022-20473, CVE-2022-20474, CVE-2022-20476, CVE-2022-20478, CVE-2022-20479, CVE-2022-20480, CVE-2022-20483, CVE-2022-20484, CVE-2022-20485, CVE-2022-20486, CVE-2022-20487, CVE-2022-20488, CVE-2022-20491, CVE-2022-20495, CVE-2022-20498, CVE-2022-20500, CVE-2022-20501, CVE-2022-20611
Changes specific to Fairphone Open:
  • Do not show notification channel warnings by default
  • Fix missing translations in Dialer app
  • Update Chromium WebView to version 108.0.5359.108
Please report any (new) issues through the public bugtracker and upvote existing issues if you are affected. As usual, please specify the steps to reproduce, and provide as many details as possible.
Not that I have an FP2 so just to say thanks and that I am impresses you still care so much.
:star_struck:
Since I needed to switch from LOS to FPOS again to make the M$ Authenticator work properly (for my work) I’m always happy that this doesn’t mean that my phone has to be out of date just because it’s six years old :+1: Thanks for keeping this up!
The update went smooth, at a first glance everything still works as it used to.
I’ll see if after this update (although no change was mentioned here) I can report anything back on the mobile data issue that some of us FP2 users (including me) are facing with FPOS.
Using that release since a while, and the only issue I have is this one:
I’m happy to have a fair, ungoogled device (as much as both are achievable today), and I’d like to thank you for the work you’ve put into this!
Danke & Grüße von
nobi
Haven’t had this for quite a while now already although I haven’t changed anything there, either (okay, carrier services are updated from time to time but I’m not sure about its actual impact).
