FP2 - does it function in Japan?
will the FP2 work in Japan with the according mobile-standards?
Thanks for your help.
You can check for yourself here:
Generally: If the frequencies are listed, it should work, but there is no guarantee. The only way to see if it works, is to test the FP2 in Japan.
Vielen Dank!
(Thread kann geschlossen werden.)
