After my FP2 discharged completely it only charges when doing a factory reset while connected to a charging cable/charger.
I tried different cable, different charger, PC USB Port, different batteries, 5 different bottom modules, cleaned the batterie contact at the core module and battery and pulled out some debris of the USB Port, however without any change. Can I conclude a core module issue, or has someone any other ideas?
Oh, you have 5 bottom modules? Maybe more as fairphone Inc. ā¦
Only one idea: How long you wait for success/life signal.
I would try 30 minutes or more.
But you wrote you tried different batteries. All discharged completely ?
When not you are right: main system problem (like core module)
Have you tried charging through the expansion port? If that doesnāt work, thereās something wrong with the core module, but if it does work, itās probably a connector issue with the bottom module (so still on the core module, but hopefully easier to fix).
On the back of the core module thereās five pogo pins in a square formation, theyāre essentially an extra USB port but itās on the core module so itās not dependent on the botttom module or its connectors.
If you take the back off your phone youāll see those pins right next to the camera button, looking like this:
ā Ā Ā Ā Ā Ā Ā Ā ā” ā 5V in, red
     ⢠ā ground, black
ā£Ā Ā Ā Ā Ā Ā Ā ā¤
Pins two and three are the ones you can use for charging. If you clip the micro-USB plug off a USB cable and then take the red and black inner cables, strip them and then touch the red cable to pin 2 and the black one to pin 3, the phone should receive a charge.
Itās fiddly but it may be worth a shot, if only for troubleshooting purposes.
thanks a lot for explaining and I will def. keep in mind for laterā¦however fiddly+electronic+me is not a good combination, Iām pretty sure whatever bad can happen it will happenš
I think the FP2 will ever stay a mistery for meā¦the last weeks I could charge when turned off, today I received the A10 upgrade and since I installed this, I can normally charge (currently charging while typing)
