FP2 Android 10: OM image share does not work
Today I also switched to the latest update. First thanks to all to port Android 10 on a more than 5 years old smartphone, so security updates still are provided. :-))
I tested several apps. One app which makes some trouble with the new version:
When geotagging images after recording a track, I got the following problem:
I am unable to connect the camera. With the previos Android 9 version, this worked flawlessly.
Only the old Olympus app
works fine but I have to use a workaround: Olympus activates a small wifi hotspot without Internet access of course. This kind of WLAN has to be actived manually first (calling the network settings). Only then I am able to add the geotag on all photographs.
I moved your post to its own topic as it does not seem to be connected to 4G connectivity
Just a shot in the dark: You might want to test if these settings make a difference:
System → Maintenance → Enhanced hardware features
I think especially Open GL might be a “candidate”.
