That depends on security issues found and cannot be put in a time scale.
Quite a number of the above replies give me the feeling that many don’t take security issues serious. Wait until your bank account has been hacked and your bank denies you any refund because of the fact that you used an old, not updated OS…
Of course there are no guarantees in life. Of course you yourself are part of (avoiding) security risks as well. But the start of all is to apply (security)updates that have been released by the supplier of the OS. That means at least updating the OS in the 4.x range.
Ultimately, it doesn’t matter WHO re-uses the phone as long as it is reused. My experience is that Fairphone has not quite figured out how to make their phones systemically useful in the long-term - i.e. for people in poor areas, especially poor countries. This requires that parts are more standardized and can be found outside of Europe, especially batteries. On this issue alone - because FP’s battery is unique and only available at an expense in Europe - it effectively prevents it from being re-used in poor countries.
In poor countries, they can usually tinker, upgrade, fix, unlock, jailbreak and otherwise keep phones running for as long as technically possible. And even if a phone becomes un-reparable, it can be scrapped for parts to make another phone work. Not so in the case of the Fairphone.
If paulakreuzer wants to really do a longevity test, he should send his phone to Nigeria and see what the real pros can do with it over the next 5 years. Unfortunately, I expect it will be very little.
Since my battery is OK, I did not yet dig into that, but is it really that non-standard? If so, we should ask Fairphone to help us locate generic batteries - as soon as they run out of stock. I would assume they will be happy to help.
They were happy to inform me that I could not use a third-party battery. That would have been a better solution than me waiting 5 weeks, paying extra delivery, and FP paying for a replacement battery and their standard delivery fee. See my longer post on this issue below:
While I really understand your frustration (I read your other posts), I would still prefer if you would not be too sarcastic about it. I honestly doubt that support sent you an email “we are happy to inform you that you can not a third party battery”. I suspect, though, they told you that if you would like to keep your warranty, you should use a original battery. Which is frustrating, but understandable.
Technically speaking, as long as the battery provides the same voltage, I don’t see any problem in using a generic one. Charging a generic battery might be a slightly different story, though. (Anyone got a qualified opinion on that?)
BTW, if I remember tonight, I shall take the measurements of the battery. Should be possible to find out which design they used - it’s hardly a “special” battery. They adopted a existing phone design from the manufacturer, so there will be other phones like it, likely with the same battery.
I admit, the sarcasm came a bit from my less-than-satisfying experience getting a replacement for a defective battery sent to me in Asia. When I originally inquired if they would send it to me, the representation flatly said “no” (i.e. have a friend in Europe forward it). Only after I read the Territoriality part of the warranty itself, did I find this:
“If you live outside Europe and want to return or repair your Fairphone, we’re still happy to help. However, you will need to cover the shipping costs.”
Given that it took them more than 3 weeks and quite a few hiccups to get the battery in the mail, I doubt they were “happy to help”. I don’t like being that ‘special case’, but should I have then blamed myself for “leaving Europe”?
As regards the battery - I remember some posts way back that discussed which existing phone model (also from Shanhong?) upon which the FP1 was based. Perhaps the battery from that phone has similar characteristics. Should this be the case, it would of course be nice if they could unofficially leak this information so that we had the choice to buy generic (at the risk of losing our warranty).
I’m not sure about this statement: batteries are not simply a sum of cells, they have also some electronics which provide current charge (in terms of instant consumption, voltage, time to empty or time to full in case of charging, and so on), healthy status, temperature and short circuit protection, so if the phone circuitry is designed to handle a specific battery (i.e. reading battery chip data and interpreting as correct values or bad status), it’s not safe to change a battery with a custom one (even if the nominal voltage and energy specifications are the same), unless you’re not sure the replacement one has the same circuitry and/or gives the data with the same ranges and values as the phone expects.
You might be right; I was oversimplifying. The battery has three contacts - so there might be an additional data line. I’ll ask someone who’s likely to be qualified about this and report back later.
Well, this is an example of a chip included in batteries, I remember in my old Nokia N900, a kernel module named bq27x00 (or something similar), used to get I2C data about battery status.
Got a kind of helpful reply from a friend with a more technical background. He said that the specifications of battery matter, which would be stored on the chip, and if we get a battery which meets general specifications, there should be no problem, because the charge controller is part of the phone and would take care of the rest.
Just for the record, he teased me a bit because there are many offers for iPhone replacement batteries on ebay, but not a single one for a Fairphone. (sigh…)
I guess we should add to the FP2 wish-list that the battery will be the same as in the next upmarket best-selling Android phone. And probably, (not only) @paulakreuzer needs to start searching for additional sources for replacement batteries, just in case the Fairphone stock runs out. Reminds me, I should probably get a second one now, just to be on the safe side.
FTR, and probably for the benefit of people like @Hart travelling Asia: if my quick web search is correct, my best guess is the WS20S battery for the HonPhone V9 should be identical to the Fairphone battery. It’s available via some online sources, but it’s not so easy to get one in Europe. I could probably ask some colleagues in Asia to bring one (they seem readily available in Singapore), but at the current exchange rate, it’s even cheaper to buy one from FP.
One reason for this might be that there are much more iphones than fairphones out there (if you search for ‘iphone’ on ebay you get 1.172.262 results, for ‘fairphone’ only 758.)
Another one is that you can buy a spare battery at the fairphone site but you can’t at apple.com.
If my battery doesn’t start to bloat but ‘just’ won’t last long anymore I can use an external battery to plug in my phone via usb. or is that dangerous with a battery that doesn’t work well anymore? I know it’s not an elegant solution but I won’t give up that easily
I think it’s the main reason. There is a larger market, so they are sold. Whole point of the argument. I conclude that a large plus for the next Fairphone would be to have the same battery as a widely sold current upmarket model.
Sidenote: I just parsed ebay. I count three genuinely FP-related offers: three people selling their FP. The rest is generic stuff, probably bot-created.
For me it’s quite simple: the only reason for me to get rid of any electronic equipment is when it stopped working and is beyond repair.
But I’m still a bit afraid that security comes in as a new factor in this case.
I will…but if I’ll find someone who wants my second hand FP1 I hope he/she will on behalf of me and I’ll try to achieve that date with a shiny FP2
Bye!
