Hello
I have a problem with my FP1 for a few days now.
It sometimes just turns off. (Suddenly the screen is black, then the screen changes from black to blue, back to black, etc. Sometimes the phone goes up again, as if you switched it on)
I could not observe that it is turning off for a certain reason or after a certain action.
Also it does it in different distances, sometimes it works normal for hours, sometimes if I restart it, it trurns off right away again.
I have done a hard reset, but nothing changed.
Does anyone have an idea what I can do?
Thank you!
Sounds like a defunct power button. This can be repaired by a #localrepairshop. Please use the search (the little magnifying glass above) to find out more about this problem.
