Hi
I’ve been reading a number of the dead FP1 threads and am following some of the links + suggestions.
However I’m wanting to post regardless as my symptoms are slightly different to the others I’ve found so far!
Backstory:
- 3 months ago my FP1 stopped turning on
- While plugged in to charge, no charge light is shown
- After partial disassembly, Battery is Good - holding a full charge
- reassembled, still wont turn on
- when plugged into PC, PC makes the noise for USB device being connected, then disconnected about 25seconds later - repeats infinitely
Goals for posting:
- ( Ideal! ) Find a miracle way to make it work again
- Find a way to extract the data from the on-board memory
Any help or suggestions greatly appreciated, i have equipment for debugging both the physical and the digital, but i lack experience physically testing circuits to find point of failure so any guidance greatly appreciated!
Cheers!
