FP Open build/make stops in TW_THEME () is not valid
Hi, I tried to build FP open and get a error with this: TW_THEME () is not valid
here the full:
bootable/recovery/gui/Android.mk:141: * TW_THEME () is not valid.
bootable/recovery/gui/Android.mk:142: * Please choose an appropriate TW_THEME or create a new one for your device.
bootable/recovery/gui/Android.mk:143: * Valid options are portrait_mdpi portrait_hdpi watch_mdpi
bootable/recovery/gui/Android.mk:144: * landscape_mdpi landscape_hdpi
As this is somehoe hardware related im not shure what the solution is…
I fond some hints at xda but as i wrote the resolutions may varry.
Did anybody else ever stumble over that?
Regards, Novski
TW_THEME is defined in /device/fairphone_devices/FP2/BoardConfig.mk:
portrait_hdpi should be a valid value, though.
Check whether your sources are well-synced:
repo init -b fp2-sibon
repo sync --force-sync
(I’m assuming here you have no local changes)
I am trying to build the Fairphone Open OS following these build instructions.
I get the same error as in this closed topic
I have tried the suggestions but cannot get it to go through. TW_THEME is well defined in /device/fairphone_devices/FP2/BoardConfig.mk:
USE_OPENGL_RENDERER := true
TW_THEME := portrait_hdpi
TW_NO_USB_STORAGE := false
TW_TARGET_USES_QCOM_BSP := true
But I get the same error everytime:
bootable/recovery/gui/Android.mk:140: ****************************************************************************
bootable/recovery/gui/Android.mk:145: ****************************************************************************
bootable/recovery/gui/Android.mk:146: *** stopping. Stop.
Any other suggestion?
