Hi guys, anyone having this trouble before and willing to help ? after charching it doesn’t turn on any more. Just the blue point appear and nothing happens… Do you know a solution for that problem ? I am unable to use it at all at the moment… Really expensive experiment this phone.
Have you managed to find this resource?
https://support.fairphone.com/hc/en-us/articles/360048350352
Was hoping there is another way around that. I already reset the phone 3 times, because I had some trouble with the camera before…
As you seem to have several issues with your device I would have tried re-installing device firmware as a pre-cursor to returning it to Fairphone if still problems:
https://support.fairphone.com/hc/en-us/articles/360048050332
Thanks! Not even rebooting is working, I think I will sent it in.
What happens if the phone is connected to the charger? What charger and cable do you use?
It is charging, battery is fully loaded it says. I am using a Hama charger, which got all the configurations asked for.
