Hi, does anyone else have a problem with the forum in Firefox 151.01.? For me it is not displayed correctly, even after deleting cache and cookies.
Seems to me that this could be some problem with scripts…
For me this is on my Linux Desktop. The mobile Version I use with Chrome
I see nothing wrong on the forum with Firefox 151.0.1 on a SUSE Linux desktop PC.
What do you mean with “not displayed correctly”? It might be something so inconspicuous I just don’t see it’s happening for me, too. ![]()
“some problem with scripts” usually sounds like maybe the built-in anti-tracking features go too far. Or maybe FF is more strict in checking the webpage compared to other browser engines. Sometimes people forget they have some extension installed that causes the problem…
And maybe the dev tools (hit F12 to show them), especially the “console” tab, show any error that’s happening.
Strange thing is, that in the same network, same OS, same Firefox version with the same addons on a different machine it works fine.
I found the solution: On the affected machine I did try to fix some other problems with certain sites and changed the user agent, and this change was applied globally to all sites instead of those sites in my whitelist (as it was intended and configured on the other machine). After fixing this, the site is being displayed correctly again.
