I’m struck by this issue either.
Today my FP3 (no FP3+) fall down and the screen flickered for a few seconds and then the display was black.
I hope after disassembling and cleaning the contacts everything will work again.
Wish me luck…
I have the same flickering issue with my FP3+
It started after I got the phone for 2 months, I didn’t drop it.
The screen sometimes will flicker for a few seconds, and then back to normal.
I can still use it, it’s just that random flickering a few times a week.
I’ll try opening it up and secure the connector.
I realised that sometimes the flickering can be caused by slight bending of the phone.
For instance, getting in or out of the phone case. The original case by Fairphone is very rigid, getting the phone out of the case needs to apply some force. My phone can flicker when I’m doing this.
I have a FP3+ for one year now and this is my first issue.
I dropped the phone onto my desk the other day. It´s in a silicon case and the drop was about an arm length deep. I didn´t worry too much about it.
Since then, I notice a weird display behavior. When the screen changes (e.g. swiping through photos, opening a new page in an app, etc.), there are a few “dancing pixels”. They appear for a few milliseconds and then they´re gone. Sometimes this also occurs with a short flash on the display. When I swipe inbetween photos of the same color, the pixels do not appear. It seems like the problem only occurs when the display color needs to change.
Anyone has any idea?
I´m grateful for any hints!
Thank you so much @anon9989719 for merging my post to this topic. I dismantled my FP3+ and cleaned it as described below. Reassembled and the issue was GONE IMMEDIATELY!!! Awesome, thanks for the quick support!
