Flickering Screen after Waterdamage to FP3
Hi all,
After dropping my phone in water and following the drying instructions from the forum, everything seemed to work fine. However, a couple of days later, I noticed a flickering/freezing screen and low to no responsiveness to touch. The phone starts fine, and rebooting it in safe mode helps for a while, but curiously (to me), the problems increase over time with increased usage. For example, opening the Maps app or browser will worsen the flickering.
Can you help me decide whether I should just get a new screen or if it is a different problem? (Cleaning contacts with isopropanol and tightening the screws around the contact didn’t help.)
Thanks in advance,
Rufus
Can you see any debris? If so carefully brush it with a copper brush.
Also press the screen all around the sides to check if it’s clicked into place.
hi thanks, for the ideas. however there is no debris there, as it fell in clean water and the screen is firmly clicked. Interestingy i noticed, that the flickering decreases/disaperas if i auto rotate screen in horizontal position…
Hi, so the Problem disappeared after replacing the screen.
