Hi fellow FP4 users,
I’ve had a flashlight problem with OpenCamera on my FP4 and found a solution. Maybe this helps if someone has a similar issue.
This is my phone setup:
- iodeOS 3.0 (3-20220530-FP4)
- OpenCamera 1.49.2 (F-Droid version, not the preinstalled from iodeOS)
And that was my issue:
Whenever I wanted to take a photo where the flash should be activated the flash was activated but a little too early. So in the resulting photo the flash was already off again and the photo was much too dark.
This is what solved my issue:
I activated the option “Use alternative flash method” in the OpenCamera app. (OpenCamera app → settings → Photo settings → Use alternative flash method)
For reference, the iodeOS version of OpenCamera did not show this issue in the first place.
