Flashingscript FP5 stuck [solved]
I recently acquired a Fairphone 5. I then briefly installed IodéOS via their installer. My banking apps didn’t work so I want to return to the stock FP5 OS.
I unloacked my bootloader, both critical and non-critical partitions, and downloaded the archive mentioned here: https://support.fairphone.com/hc/en-us/articles/18896094650513-Installing-Fairphone-OS-Manually
Now when I try to run the flashing script in the archive it recognizes the phone but then seems to be stuck sending the first file.
All I see is " Sending ‘abl_a’ (152 KB)"
No error is given and closing the script and running it again does not work.
The phone is still able to boot into IodéOS, for now.
Any suggestions on what I can try to get back to the stock OS?
Kind regards,
Felix
Edit: Solved it by selecting File transfer instead of Charging only in the USB menu.
