I received my Fairphone Monday evening. The following is my first impression.
(I’ve honestly barely used it, but I am confident something like watching a video has improved beyond my lower limits, and the same for battery life.)
Somehow, I am able to keep a firm, natural grip on it. How this is going to work out e.g. during commute we will have to see. The machine is quick compared to FP2, and the screen is gorgeous (and large compared to FP2, with a higher screen to body ratio but not as high as the trend). I try to be content with less good screens, but I’m a sucker for it (MBP Retina is also gorgeous). In order to install the SIM card I had trouble getting the battery out with my nails (partner couldn’t do it either). Had to use a tool on my pocket knife. Not something I’ll want to do often (I guess it was to compensate for the design flaw in FP2 battery). Fingerprint and NFC work flawless (I’ve used the latter together with my national ID card). I’m still in the process of migrating which goes a bit slower because no cloud backups being used (more hereunder).
I’m puzzled by Google’s choice to suggest different search engines which end up just wrappers around WebView (Chrome), and separate “browsers”, while they did not offer the option of Firefox. I had to manually install Firefox Preview in Google Play Store instead. Also, I had trouble obtaining applications I already purchased on my Google account. It just mentioned the price, not the option to download. If I clicked on the price, it eventually said I already owned that application.
I made a thermal picture of the smartphone lying idle for 5 minutes after booting up to the config screen. I intend to make some more pictures with my thermal camera, but I want to document clearly the circumstances / use case. Any requests on that matter? One I was thinking of, was having the screen on 50% brightness, and watching Netflix or Prime Video for say 10 minutes.
I’ve managed to avoid Google Drive automatic backups, and am using DAVx5 + Nextcloud + WireGuard for my calendar/contacts. I have not attempted to save my WhatsApp data as the pictures/videos of my child are the most important, and they are backed up automatically with the previously mentioned software.
One feature I miss coming from LOS 16 (= Android 9 + mods) is the option to scramble your PIN. Without this option, a PIN is as secure as a pattern (very easy to leak if you watch over shoulder).
[EDIT1]My FP3 barely fits my old Feuerwear case which I used with the FP2 (the Velcro has worn out)[/EDIT]
[EDIT2]The front camera field seems slightly odd, the fingerprint sensor would ideally sit a little bit lower, and the USB-C port not being in the middle makes a FLIR camera on the bottom not a good fit (I already bought a standalone though).[/EDIT]
