@H2O Sorry, I don’t have a FP3
I checking the prerequisites to get on, some day…
never mind, thanks anyway, I still have time.
I won’t decide until next year, at least if my current FP2 doesn’t die
About the best well-known and complete call recorder would be ACR. However, in Android 9, Google introduced limitations for call recording. It still works with the internal speaker on, but when the speaker is off, the other side is not recorded. So, it’s not FP’s fault, but Google’s policy.
In Android 10, call recording will be completely blocked.
You can read all about it here.
Thank you,
another feature loss, that doesn’t sound very tempting!
Ridiculous. Call recording is a very useful feature which can allow you to create a legal case. I grew up with a blind father, and he had a call recorder in the 80s. Because he also had bad memory (and because people can forget, or be scumbags) he recorded a lot of phone conversations. All. The. Time. And now Google tells me I am not allowed to do that?
Not that I support Google’s decision, but isn’t it kind of the law (in some countries, at least) which tells you that you are not allowed to do that? At least without consent from both parties. I would be inclined to believe the decision to remove this feature being easily available to everyone all the time to be privacy inspired. I also cannot really think of another reason for doing so which would benefit Google.
I’m not even specific anti-Google.
I’m just very much not interested in Google limiting my freedoms which I am allowed to exercise in my jurisdiction just like I am not interested in Microsoft, Apple, etc doing that.
And while it is not black and white allowed in my jurisdiction [1] (which describes both my father’s use case, as well as how it can strengthen your legal position, and how it is allowed to record as a consumer if you’re taking part of the conversation; I also know Arnoud Engelfriet wrote about it on his blog). Google is not the police who tells me I am not allowed to record my phone calls. In fact, it is downright harmful that they do not allow me to record my own phone calls. It makes me furious. Then again, if it was just never possible in the first place, I might have been used to that instead.
[1] http://blog.wetrecht.nl/telefoongesprekken-opnemen-als-bewijs-kan-dat/
Despite having an estimated delivery of mid-November, my FairPhone 3 arrived last week. I’m very happy with the general user experience, build quality and performance thus far, but for this post will be focussing on a couple of the nitty-gritty details of functionality that might be useful to others.
Mobile Internet, APN settings & Bouygues Telecom
If you’re on Bouygues Telecom in France (a core operator, not an MVNO), the FP3 will automatically connect for voice and SMS, but multiple users of the company’s support portal indicate that internet and MMS don’t work on the FP3 with default settings.
It was certainly an issue for me when transferring settings from an old Google Nexus 4. To fix this, under Network & Internet > Mobile network > Access Point Names > Bouygues Télécom, add PAP as your Authentication type. I also switched to IPv4/IPv6 under APN protocol and replaced default,supl,mms with default,supl,mms,ia under APN type. Delete the contents of the MMS Port and MMS Proxy entries.
Et en français pour des moteurs de recherche:
Si vous êtes avec Bouygues, vous pouvez trouver que l’internet mobile ne fonctionne pas avec les paramètres défauts. Sous Réseau et internet > Réseau mobile > Noms des points d’access > Bouygues Télécom, ajouter PAP pour Type d’authentification. J’ai aussi utilisé IPv4/IPv6 pour Protocole APN et remplacé default,supl,mms par default,supl,mms,ia sous Type d’APN. Supprimez les paramètres Proxy MMS et Port MMS.
VPN services not functioning
OpenVPN clients from two services (NordVPN and ExpressVPN) are failing to connect. I’ve just discovered this issue so don’t have much more detail right now. This is a non-negotiable feature for me, as I review VPN providers for work, so I’ll be prioritising diagnosis and remediation !
I’m using the NordVPN app and its working fine…
(Orange network)
I had no real problems with FP3 but think that is is advisable to ask the telephone provider for correct APN settings.
My old FP2 is used within family and I had a lot of complaints about internet connection via mobile network. Comparing FP3 and FP2 on the same spot showed that FP3 connected with 4G but FP2 only with 2G.I also wrote a mail to Drillisch (o2) and asked for settings. What I got was completely different from the official internet info of o2 but slightly different from the automatic APN install of FP3.
I now use APNs I got from Drillisch for both smartphones with following results:
FP3: It seems that speed is still better
FP2: Also connects with 4G
My feeling is that even in the same network like o2 the smaller providers use slightly different APNs.
Just got the Fairphone 3 having never owned one before (1 or 2) and I think like it. I’ve never spent as much on a phone (or will have in 24 months time). It seems fairly nippy and I’m very happy with the battery and screen. One thing I can’t seem to find out how to do is to set different notification sounds for SMS and incoming calls depending on the SIM. If the option exists somewhere in the menu, could someone please tell me where exactly to find it? Thanks. Apologies if this has already been mentioned.
I do agree that a hard case is required (as I’m clumsy), but not that FF should produce one . Phone is new so I expect more covers will hit the market place in time, but the only one I can find uses adhesive and a slide. I’d prefer a wallet with camera and fingerprint holes myself (personal preference). Bumper is a pretty neat idea in the meantime. I also agree that LEDs should be able to reflect received notifications. Shame they don’t… yet?
I’m not against bloatware per-se, but dead against not being able to un-install it, so I’m pleased it only came with the Google junk. Regarding the “Google” app, I have disabled that, but it can’t be uninstalled as far as I can see. So now I have a dead searchbar on my home screen, not annoying enough to get a different launcher though.
Hah, yes - that’s certainly preferable. I hope Bouygues eventually starts providing correct information when asked.
(Orange network)
Interesting, and very encouraging, thank you. I’ll remove VPN profiles from the phone and start again from scratch. It’s possible I hit an install-time issue that’s not entirely apparent. Are you using the APK from NordVPN’s site or the Play Store version of the app?
Just received my fairphone3. Owned a fairphone2, but due to lacking operating systems, several services didn’t work anymore. Hence the new phone.
So far, I really like it. However:
-the communication is aimed at new customers and not existing once. No answers or easier option to transfer your date from 2 to 3. Of course I can use the instructions for Android users in general. But it’s just not s good service.
- same with the cable. Why don’t you point out somewhere for your existing clients that my old charger won’t work? Sorry for not speaking tech!
- same with sim . Doesn’t fit! So I loose one day to get new charger and second to get new SIM?
I find this very disappointing!
The support section of the website has tutorials …
https://support.fairphone.com/hc/en-us/categories/360002044272
Including …
Im very aware oft this and consulted everything. Just saxing that there should be a section for existing customers si wont habe to search and hit and miss so much. All good now. Well i hope, still waiting in my New sim card
Hello, I have the same problem. I just resolved the problem of 4G network with Bouygues in France, and also MMS that I don’t received with the forum (thank you guys) but unfortunately VPN (Express VPN) doesn’t work. If you have fixed your problem, I am really interesting.
Thank you
My Fairphone 3 arrived yesterday and so far, I’m quite happy. It’s sturdy, fast and looks good. Overall a good improvement over the FP2.
However, even though I have tall hands, the screen is a little too big to use with one hand (at least when trying to reach the top and bottom of the screen).
It also seems like the adaptive battery feature from Android 9 isn’t implemented.
Furthermore the bumper seems a little loose on the sides and you can get a little “stuck” with your finger. It could have a little tighter.
Edit: The screen is way too bright on its lowest settings. This one should really be fixed in an upcoming update.
I’ve been working on this, and unfortunately, it looks as though certain of Bouygues’ network settings are mutually incompatible with VPN traffic. The usual solution offered is to make sure APN authentication type is set blank and protocol set to IPv4/IPv6 - this worked perfectly on several of my previous phones.
But for the FP3 to have working 4G access on Bouygues, it needs authentication type to be set to PAP, so we’re still at an impasse here.
Things that make no difference to VPN (non)functionality:
forcing the VPN app to use TCP if available
switching DNS resolver in the VPN client
dropping APN protocol to IPv4
manually setting up an IKEv2/IPSec connection using strongSwan at default settings
It looks as though it may also be an issue of default UDP port selection, based on what Bouygues staff have said in some forums.
I’m continuing to poke at this and will post here if I find any solution.
Further references:
https://lafibre.info/vpn/openvpn-impossible-chez-certains-operateur/
