Hello!
Could you please tell me if you use fingerprint access? How reliable is this method?
I will be grateful for your help!
Access for what and which phone?
I use it for unlocking the phone and Signal, which are fine, unless iâve just washed my hands etc.
Well I only commented that it works not the security issue, so much so that I donât think itâs more secure than a password etc. Well not in my case.
My fingerprints can be copied from anything I touch in theory but getting into my head for my password would be truly ugly and painful.
Though with the brute force that computers could use they could circumvent my head.
My theory is that if I am such an important target, phone and online security is the least of my worries.
So I canât say fingerprint reading is more secure and I donât like biometric ID-ing but it works, well again some people have problems.
Modern fingerprint readers shouldnât be that easy to fool:
I wouldnât trust any fingerprint reader. First of all, if I suspect someone got to know my password, I can just change it anytime. If someone was able to copy my fingerprint, what can I do? No way to order a fresh replacement finger
Then, optical and Capacitive sensors are really easy to trick, you wonât even need expensive tools or materials. If you want to go more in depth, Iâd recommend this link for starters:
This paper doesnât cover ultrasonic sensors, but as any other technology was proven to be unreliable, I guess itâs just a matter of time until someone cares enough to rip them apart also.
At least youâve got ten of them.
I canât read this dark mode pdf, but looks like it was written 2006, itâs 2023 now.
Unfortunately my post about fingerprint security was deleted pretty quick.
Well, I won´t mention any details about it anymore but please keep my statement alive:
Fingerprint access/security is not secure.
Best
DonFnord
PS: Listen to @struppi ´s wise words like this:
If your security measurements become breached âsomehowâ then you can easily reset a password/-phrase. That´s not as easy as replacing a finger
/edit
PPS: Thanks to the moderation team for giving feedback about the deletion. Makes sense!
