FF3; GPS doesn't work
Hi, on my FF3 with e/ os installed, it seems that GPS don’t work animore.
I’ve installed SatStat and that app doesn’t show me any satellites How can I check if gps module works well or if there are some os configuration wrong?
Thank you
Renato
The best way of checking if your GPS is working is through the test menu
  • Open the Phone app.
  • Dial ##66##** in the same way you are entering a phone number to make a phone call. Once the last character is introduced, the Service Menu appears.
  • Select Service tests > Test Single.
  • Select GPS
The test menu is not available in /e/OS.
And the forum software doesn’t like the notation, but you can use “Preformatted text” in the editor … *#*#66#*#* :wink: .
Corresponding topic in the /e/OS forum … GPS: how can I be sure to have it enabled? - Settings - /e/OS community
Best App to check is https://play.google.com/store/apps/details?id=com.android.gpstest
