Title. Since the Android 14 update the system does not register data transfer cables anymore. Worked perfectly before.
This is an extremely critical error and will force me to buy a new phone if that is not fixed ASAP.
You know telling us user will not help to fix it? Did you contact FP support?
Edit: cant reproduce just tested
Where did I tell anyone to do anything? I am describing the potential consequences of the current status quo.
As for contacting support: The description of this forum is âFind solutions and ask community for help with your FP product. If you have a HW or SW issue this is the right place.â
So thatâs what Iâm doing: Asking in âthe right place.â
I moved your post to the discuss section, as this statement is contradictory to asking for help from other users.
Edit as a little reminder:
No problems here.
Tip : make sure the phone is unlocked and screen on when you attach the cable.
After attaching the cable, make sure that File transfer is selected in
Settings > Connected devices > USB
And of course, there could be a problem with the cable (try another), the phoneâs USB port or the PCâs USB port (try another).
I donât think Hahnfruhâs question is about registering with Fairphone as a phone owner. Just the data cable isnât recognized. The problem may have nothing to do with the Android 14 update.
For sure it isnt and only remind them that they are still not talking to FP here
No, you donât ask anything, you (with your own words) âdescribing the potential consequences of the current status quo.â
You also donât post any information, what is your FP5 OS, PC/NB OS, what cable you use, what you (if any) try to resolve, etcâŚ
Anyway, you problem is not global, maybe not problem with FP5 but with your setup/cable/computerâŚ
With my FP5, stock Android14, NB with Linux Xubuntu 22.04 i donât have any problem, and work:
Others data related working use of USB-C in FP5:
So, based on your used OS:
