I tried to install iode OS. Unfortunately the installation got stuck at some point and the Fairphone 5 got stuck at fastboot/ recovery menu. Any guides on how to proced? Yes, I searched, but could not find a working guide.
Is the bootloader still unlocked if so why not just doing it again?
It is unlocked. But the phone does not boot. So I can not get through the installer again.
So then install FPOS manually (dont lock the bootloader) and start again with Iode
Or install Iode manually…
I tried the manual install of Iode (which failled at the same point) and to reinstall Fairphone with the linked script. Tried both versions of the script (FP5-TT40-factory and FP5-TT4-factory). The script ended in both cases with “Info: One Fairphone 5 in fastboot mode found (serial number: xxxxxxx)”
Here some infos about my device. I picked this up, from another thread, but I am not that knowledgeable about that stuff.
fastboot getvar all
(bootloader) cpu-abi:arm64-v8a
(bootloader) snapshot-update-status:none
(bootloader) super-partition-name:super
(bootloader) is-logical:sdc:no
(bootloader) is-logical:vbmeta_system_a:no
(bootloader) is-logical:aop_b:no
(bootloader) is-logical:abl_a:no
(bootloader) is-logical:xbl_b:no
(bootloader) is-logical:aop_a:no
(bootloader) is-logical:imagefv_b:no
(bootloader) is-logical:abl_b:no
(bootloader) is-logical:uefisecapp_a:no
(bootloader) is-logical:cpucp_b:no
(bootloader) is-logical:boot_a:no
(bootloader) is-logical:hyp_a:no
(bootloader) is-logical:xbl_config_b:no
(bootloader) is-logical:devcfg_b:no
(bootloader) is-logical:vbmeta_a:no
(bootloader) is-logical:keymaster_a:no
(bootloader) is-logical:hyp_b:no
(bootloader) is-logical:multiimgoem_a:no
(bootloader) is-logical:qweslicstore_a:no
(bootloader) is-logical:featenabler_a:no
(bootloader) is-logical:mdtpsecapp_a:no
(bootloader) is-logical:keymaster_b:no
(bootloader) is-logical:mdtpsecapp_b:no
(bootloader) is-logical:vendor_boot_b:no
(bootloader) is-logical:shrm_b:no
(bootloader) is-logical:imagefv_a:no
(bootloader) is-logical:misc:no
(bootloader) is-logical:sda:no
(bootloader) is-logical:dsp_b:no
(bootloader) is-logical:featenabler_b:no
(bootloader) is-logical:cpucp_a:no
(bootloader) is-logical:xbl_a:no
(bootloader) is-logical:userdata:no
(bootloader) is-logical:modem_a:no
(bootloader) is-logical:mdtp_a:no
(bootloader) is-logical:qupfw_b:no
(bootloader) is-logical:uefisecapp_b:no
(bootloader) is-logical:dtbo_a:no
(bootloader) is-logical:vendor_boot_a:no
(bootloader) is-logical:tz_a:no
(bootloader) is-logical:modem_b:no
(bootloader) is-logical:bluetooth_b:no
(bootloader) is-logical:mdtp_b:no
(bootloader) is-logical:ssd:no
(bootloader) is-logical:xbl_config_a:no
(bootloader) is-logical:qweslicstore_b:no
(bootloader) is-logical:multiimgoem_b:no
(bootloader) is-logical:sdf:no
(bootloader) is-logical:qupfw_a:no
(bootloader) is-logical:shrm_a:no
(bootloader) is-logical:tz_b:no
(bootloader) is-logical:dsp_a:no
(bootloader) is-logical:bluetooth_a:no
(bootloader) is-logical:sde:no
(bootloader) is-logical:sdb:no
(bootloader) is-logical:devcfg_a:no
(bootloader) is-logical:sdd:no
(bootloader) is-logical:metadata:no
(bootloader) is-logical:super:no
(bootloader) is-logical:vbmeta_system_b:no
(bootloader) is-logical:boot_b:no
(bootloader) is-logical:vbmeta_b:no
(bootloader) is-logical:dtbo_b:no
(bootloader) is-logical:odm_a:yes
(bootloader) is-logical:odm_b:yes
(bootloader) is-logical:product_a:yes
(bootloader) is-logical:product_b:yes
(bootloader) is-logical:system_a:yes
(bootloader) is-logical:system_b:yes
(bootloader) is-logical:system_ext_a:yes
(bootloader) is-logical:system_ext_b:yes
(bootloader) is-logical:vendor_a:yes
(bootloader) is-logical:vendor_b:yes
(bootloader) battery-voltage:0
(bootloader) treble-enabled:true
(bootloader) is-userspace:yes
(bootloader) partition-size:sdc:0x800000
(bootloader) partition-size:vbmeta_system_a:0x10000
(bootloader) partition-size:aop_b:0x80000
(bootloader) partition-size:abl_a:0x100000
(bootloader) partition-size:xbl_b:0x385000
(bootloader) partition-size:aop_a:0x80000
(bootloader) partition-size:imagefv_b:0x200000
(bootloader) partition-size:abl_b:0x100000
(bootloader) partition-size:uefisecapp_a:0x200000
(bootloader) partition-size:cpucp_b:0x100000
(bootloader) partition-size:boot_a:0x6000000
(bootloader) partition-size:hyp_a:0x800000
(bootloader) partition-size:xbl_config_b:0x3A000
(bootloader) partition-size:devcfg_b:0x20000
(bootloader) partition-size:vbmeta_a:0x10000
(bootloader) partition-size:keymaster_a:0x80000
(bootloader) partition-size:hyp_b:0x800000
(bootloader) partition-size:multiimgoem_a:0x8000
(bootloader) partition-size:qweslicstore_a:0x40000
(bootloader) partition-size:featenabler_a:0x20000
(bootloader) partition-size:mdtpsecapp_a:0x400000
(bootloader) partition-size:keymaster_b:0x80000
(bootloader) partition-size:mdtpsecapp_b:0x400000
(bootloader) partition-size:vendor_boot_b:0x6000000
(bootloader) partition-size:shrm_b:0x20000
(bootloader) partition-size:imagefv_a:0x200000
(bootloader) partition-size:misc:0x100000
(bootloader) partition-size:sda:0x3A10800000
(bootloader) partition-size:dsp_b:0x4000000
(bootloader) partition-size:featenabler_b:0x20000
(bootloader) partition-size:cpucp_a:0x100000
(bootloader) partition-size:xbl_a:0x385000
(bootloader) partition-size:userdata:0x3580273000
(bootloader) partition-size:modem_a:0xDC00000
(bootloader) partition-size:mdtp_a:0x2000000
(bootloader) partition-size:qupfw_b:0x14000
(bootloader) partition-size:uefisecapp_b:0x200000
(bootloader) partition-size:dtbo_a:0x1800000
(bootloader) partition-size:vendor_boot_a:0x6000000
(bootloader) partition-size:tz_a:0x400000
(bootloader) partition-size:modem_b:0xDC00000
(bootloader) partition-size:bluetooth_b:0x400000
(bootloader) partition-size:mdtp_b:0x2000000
(bootloader) partition-size:ssd:0x2000
(bootloader) partition-size:xbl_config_a:0x3A000
(bootloader) partition-size:qweslicstore_b:0x40000
(bootloader) partition-size:multiimgoem_b:0x8000
(bootloader) partition-size:sdf:0x2000000
(bootloader) partition-size:qupfw_a:0x14000
(bootloader) partition-size:shrm_a:0x20000
(bootloader) partition-size:tz_b:0x400000
(bootloader) partition-size:dsp_a:0x4000000
(bootloader) partition-size:bluetooth_a:0x400000
(bootloader) partition-size:sde:0x180000000
(bootloader) partition-size:sdb:0x800000
(bootloader) partition-size:devcfg_a:0x20000
(bootloader) partition-size:sdd:0x2000000
(bootloader) partition-size:metadata:0x1000000
(bootloader) partition-size:super:0x180000000
(bootloader) partition-size:vbmeta_system_b:0x10000
(bootloader) partition-size:boot_b:0x6000000
(bootloader) partition-size:vbmeta_b:0x10000
(bootloader) partition-size:dtbo_b:0x1800000
(bootloader) partition-size:odm_a:0xE6A1000
(bootloader) partition-size:odm_b:0x0
(bootloader) partition-size:product_a:0x5E901000
(bootloader) partition-size:product_b:0x0
(bootloader) partition-size:system_a:0x45162000
(bootloader) partition-size:system_b:0x0
(bootloader) partition-size:system_ext_a:0x26D8C000
(bootloader) partition-size:system_ext_b:0x0
(bootloader) partition-size:vendor_a:0x4A0EE000
(bootloader) partition-size:vendor_b:0x0
(bootloader) version-vndk:33
(bootloader) partition-type:sdc:raw
(bootloader) partition-type:vbmeta_system_a:raw
(bootloader) partition-type:aop_b:raw
(bootloader) partition-type:abl_a:raw
(bootloader) partition-type:xbl_b:raw
(bootloader) partition-type:aop_a:raw
(bootloader) partition-type:imagefv_b:raw
(bootloader) partition-type:abl_b:raw
(bootloader) partition-type:uefisecapp_a:raw
(bootloader) partition-type:cpucp_b:raw
(bootloader) partition-type:boot_a:raw
(bootloader) partition-type:hyp_a:raw
(bootloader) partition-type:xbl_config_b:raw
(bootloader) partition-type:devcfg_b:raw
(bootloader) partition-type:vbmeta_a:raw
(bootloader) partition-type:keymaster_a:raw
(bootloader) partition-type:hyp_b:raw
(bootloader) partition-type:multiimgoem_a:raw
(bootloader) partition-type:qweslicstore_a:raw
(bootloader) partition-type:featenabler_a:raw
(bootloader) partition-type:mdtpsecapp_a:raw
(bootloader) partition-type:keymaster_b:raw
(bootloader) partition-type:mdtpsecapp_b:raw
(bootloader) partition-type:vendor_boot_b:raw
(bootloader) partition-type:shrm_b:raw
(bootloader) partition-type:imagefv_a:raw
(bootloader) partition-type:misc:raw
(bootloader) partition-type:sda:raw
(bootloader) partition-type:dsp_b:raw
(bootloader) partition-type:featenabler_b:raw
(bootloader) partition-type:cpucp_a:raw
(bootloader) partition-type:xbl_a:raw
(bootloader) partition-type:userdata:raw
(bootloader) partition-type:modem_a:raw
(bootloader) partition-type:mdtp_a:raw
(bootloader) partition-type:qupfw_b:raw
(bootloader) partition-type:uefisecapp_b:raw
(bootloader) partition-type:dtbo_a:raw
(bootloader) partition-type:vendor_boot_a:raw
(bootloader) partition-type:tz_a:raw
(bootloader) partition-type:modem_b:raw
(bootloader) partition-type:bluetooth_b:raw
(bootloader) partition-type:mdtp_b:raw
(bootloader) partition-type:ssd:raw
(bootloader) partition-type:xbl_config_a:raw
(bootloader) partition-type:qweslicstore_b:raw
(bootloader) partition-type:multiimgoem_b:raw
(bootloader) partition-type:sdf:raw
(bootloader) partition-type:qupfw_a:raw
(bootloader) partition-type:shrm_a:raw
(bootloader) partition-type:tz_b:raw
(bootloader) partition-type:dsp_a:raw
(bootloader) partition-type:bluetooth_a:raw
(bootloader) partition-type:sde:raw
(bootloader) partition-type:sdb:raw
(bootloader) partition-type:devcfg_a:raw
(bootloader) partition-type:sdd:raw
(bootloader) partition-type:metadata:raw
(bootloader) partition-type:super:raw
(bootloader) partition-type:vbmeta_system_b:raw
(bootloader) partition-type:boot_b:raw
(bootloader) partition-type:vbmeta_b:raw
(bootloader) partition-type:dtbo_b:raw
(bootloader) partition-type:odm_a:raw
(bootloader) partition-type:odm_b:raw
(bootloader) partition-type:product_a:raw
(bootloader) partition-type:product_b:raw
(bootloader) partition-type:system_a:raw
(bootloader) partition-type:system_b:raw
(bootloader) partition-type:system_ext_a:raw
(bootloader) partition-type:system_ext_b:raw
(bootloader) partition-type:vendor_a:raw
(bootloader) partition-type:vendor_b:raw
(bootloader) has-slot:sdc:no
(bootloader) has-slot:vbmeta_system:yes
(bootloader) has-slot:aop:yes
(bootloader) has-slot:abl:yes
(bootloader) has-slot:xbl:yes
(bootloader) has-slot:imagefv:yes
(bootloader) has-slot:uefisecapp:yes
(bootloader) has-slot:cpucp:yes
(bootloader) has-slot:boot:yes
(bootloader) has-slot:hyp:yes
(bootloader) has-slot:xbl_config:yes
(bootloader) has-slot:devcfg:yes
(bootloader) has-slot:vbmeta:yes
(bootloader) has-slot:keymaster:yes
(bootloader) has-slot:multiimgoem:yes
(bootloader) has-slot:qweslicstore:yes
(bootloader) has-slot:featenabler:yes
(bootloader) has-slot:mdtpsecapp:yes
(bootloader) has-slot:vendor_boot:yes
(bootloader) has-slot:shrm:yes
(bootloader) has-slot:misc:no
(bootloader) has-slot:sda:no
(bootloader) has-slot:dsp:yes
(bootloader) has-slot:userdata:no
(bootloader) has-slot:modem:yes
(bootloader) has-slot:mdtp:yes
(bootloader) has-slot:qupfw:yes
(bootloader) has-slot:dtbo:yes
(bootloader) has-slot:tz:yes
(bootloader) has-slot:bluetooth:yes
(bootloader) has-slot:ssd:no
(bootloader) has-slot:sdf:no
(bootloader) has-slot:sde:no
(bootloader) has-slot:sdb:no
(bootloader) has-slot:sdd:no
(bootloader) has-slot:metadata:no
(bootloader) has-slot:super:no
(bootloader) has-slot:odm:yes
(bootloader) has-slot:product:yes
(bootloader) has-slot:system:yes
(bootloader) has-slot:system_ext:yes
(bootloader) has-slot:vendor:yes
(bootloader) security-patch-level:2024-02-05
(bootloader) hw-revision:0
(bootloader) current-slot:b
(bootloader) serialno:xxxxxxxx
(bootloader) product:FP5
(bootloader) version-os:13
(bootloader) first-api-level:33
(bootloader) slot-count:2
(bootloader) max-download-size:0x10000000
(bootloader) version:0.4
(bootloader) version-baseband:
(bootloader) secure:yes
(bootloader) dynamic-partition:true
(bootloader) unlocked:yes
all:
Finished. Total time: 0.841s
Critical ist auch unlocked? Welches OS ist auf deinem Rechner installiert?
KDE Neon? Was ist “Critical”?
Also Linux!? Da gab es Probleme mit fastboot… Evtl mla ne ältere Version testen oder aktualisieren falls nicht aktuell?
Zum Bootloader unlocken (mind zim installieren von FPOS) gibt es 2 Schritte , einer ist unlock critical
KDE Neon basiert auf Ubuntu 22.04. Der Bootloader war eigentlich bereits unlocked oder sagen meine Daten da was anderes?
Naja Ubuntu ist doch Linux? Ob du beides unlocked hast weisst nur du soweit ich weiss ist unlock critical nicht überall notwendig und im fastboot modus würde das gerät auch ohne unock critical anzeigen, das der Bootloader unlocked ist.
I am now stuck in a new situation. After plugin, it is into Windows, the phone is permanently off or at least the screen is dark. The FP5 it is recognised in the device manager as Qualcomm HS-USB- QDL 9008
Have you done anything else then trying to use a windows PC? Overall I guess in this state only Fairphone can help you, so would advise to contact support.
