Hi, does anyone know of any places that repair Fairphones in Glasgow? (I have a problem with my microphone in my Fairphone 3+)
Thanks, Ruth
Thanks, Ruth
There is an Fairphone Angel in the region of Edinburgh.
What is wrong with your microphone?
Did it happen just after an update?
Thanks, I tried emailing them but it bounced back
The microphone is very muffled - when I make a call, it only works if I have it on speaker (& I can’t leave voicenotes on whatsapp, for example)
I don’t think it happened just after an update - I can’t think of anything that would have triggered it
You wrote to edinburgh@fairphone.community, right? ![]()
If it was edinburgh@fairphone.com then it’s wrong. ![]()
Hi, thanks - yes I wrote to the first one
Thank you, I’m marking @alex.a and @Volker here to have a look at the email issue.
On your microphone issue, you can do a hardware test yourself. Dial * # * # 6 6 # * # * to access a wide range of tests. This should help to make certain if it is a hardware or a software issue.
@P1000 in case you read this maybe you can get in contact via PM
I’ve sent a test mail. It reached the Edinburgh (angels) group and didn’t bounce.
ok, thanks - i’ll try again
Hi Ruth, would love to know if you get a reply from the FP angel in Edinburgh as I emailed them a couple of weeks back but haven’t heard back…
Nice to know of a Fairphone user not far away (I’m in central Edinburgh) ![]()
It seems that this time it has worked. I just don’t know if the local Angel will have time to answer or not…
Ok, does anyone know of any phone repair places in Glasgow/Edinburgh/Central Belt that will look at Fairphones?
