Fairphone owners in the USA (FP2 FP3 FP4 FP5)
6 posts were merged into an existing topic: Rooted Fairphone 4 With Lineage for Microg version 20 for Sale in the United States
This is absolutely bewildering - my FP5 will consistently receive small MMS videos (<3MB) as a thumbnails + a .qcp file, medium MMS videos <30-34MB as just a thumbnail and large >=34MB MMS videos. Popping the same SIM/APN values into my Pixel4a5g on LOS receives all video MMS just fine. I’ve tried several different SMS apps, so I know it’s not on that layer. It must be either something in the FP firmware or eOS. Any thoughts?
Which country + provider and any chance to test another SIM, best from a different provider?
US on a Verizon MVNO (US Mobile). I know FP5 isn’t officially supported for Verizon yet, but everything else works great. Unfortunately I don’t have another provider to test and wouldn’t want to switch just for video MMS. Was hoping someone might know a little bit about the video MMS mechanics for this scenario, since it’s such a strange and specific issue, and if I could fix it, then I could say the phone works perfectly for the second largest mobile phone network provider in the US.
To increase the chance to get help I moved your post here, maybe anyone in the US has/had the same issues. Also if not yet done ask in the murena forum, they can probably look into it.
Done … eOS FP5 only receives and plays large video MMS files, small files are thumbnails - Fairphone - /e/OS community
Update: I have now returned this phone to the latest stock OS and have relocked the bootloader. If it doesn’t sell in this forum in the next two days, I will post it on Ebay and/or Swappa.
Funny. I can’t send a file on T-mobile without degrading the video file to less than 32mb when the US limit on any network is 100mb as the file size limit. I have to use the Luma Fusion video editor to re-edit the file in question to 240p at the lowest bit rate to send via MMS. The reason is that anything over the 32mb limit will try to compress the file to a shorter video length with bad quality. I used to edit video as a living. I used windows movie maker 2012 and Devinchi Resolve on windows. A 20min 1080p video is about 2GB. Try to compress that into a 32mb file is difficult to do without lowering the resolution, bit rate, and the length of the video to like 5Min. So all I do is just send pictures and gifs over the T-mobile MMS network. I can’t get any video to work. This is however not an issue with straight talk with my mothers Samsung Galaxy S20 FE. It got to be something with FairPhone products itself, because that shouldn’t be an issue. The only way otherwise is upload to a cloud server and send a link to anyone through MMS
(Settings used on Luma Fusion compressed 84MB Xbox Game Capture to an Estimate of 7.4mb)
Well under the 32mb limit. A a 5min clip. I’ll update you after rendering the video if if it was successful on MMS
It was successful. Just remember the size limit. You might have to get this app or edit it on another computer to send a MMS video.
Just to update. The Fairphone 5 that I received, I put in the Mint Mobile sim and it picked up as T-Mobile even after putting in Mint’s APN details. However, everything is working great with Mint, after feeding their apn details in I can make and receive calls. I get here in NJ generally full bars on 4G/5G all over this area via Mint/T-Mobile.
Hello, Is anyone looking to sell their Fairphone? I am located in MN. I want to get one to experiment with. I am open to any Fairphone with a usb-c charging port. I also have experience with /e/OS. Thank you!
Just be aware that us owners can get a fairphone on Amazon. It will take a week to get here. Both new and used. Just FYI. You can also try the marketplace here as well.
After a few years of success, my FP3 started getting blocked by T-Mobile towers in NYC area this week (zero data, can’t use voice). Strangely, here in Maryland area, it’s not blocked yet. (I shelled out for a hotspot on Verizon to get around this disaster)
I am leaning towards buying a FP5 to remedy, with the hope that part of why I am blocked is not having 5G.
It’s disappointing because the FP3 works perfect besides carrier arbitrarily not accepting it.
ā€œBlockedā€ may be a bit misleading, to me this implies that the carrier is deliberately refusing the service. It may just be that the towers in question have been re-equipped and that their new configuration is not compatible with the FP3’s 3G/4G/LTE capacity.
When this happens, have you tried setting the preferred network type to 2G/3G or even 2G? I’ve no idea what’s available but that might possibly enable voice calls and SMS, though of course Internet connectivity would be appalling.
This setting is in Settings > Network and Internet > SIMs > [your SIM] > Preferred network type.
Yes, that would likely be a solution.
And one week later, FP3 is working again after dishing out for FP5.
FP3 is rejected by something for days at a time now. Going to cutover to FP5 now.
I was using my new FP5 with Verizon network in USA and it seemed to work fine.
Switching to Mint Mobile to save some costs. Failed to setup their eSIM. Their tech support tells me that the FP5 is ā€œnot supportedā€ for eSIM but will work fine with a physical SIM.
Hi and welcome to the forum,
Moved your post here, maybe you find some info above or someone has experience with eSIM from Mint.
i’ll report back when I receive the physical SIM.
Mint mobile is a T-Mobile service… I remember seeing people going to a T-Mobile store to deal with tech support. It took them two days to set mine up. The reason this is still a problem. Its because of both companies got rid of the QR code and they have to manually download the eSim in the store. I hope this helps you with your problem.
I’ll try this out. Thank you for the idea :pray:
