Fairphone (generation 6) launched 25 June
In case of contact to water you could quickly disconnect the battery connector after removing the back.
Pic 41: There seems to be a rubber protecting the SD card. I guess you can just insert any SD card.
Except for the change of file system, SDXC cards are mostly backward compatible with SDHC readers, and many SDHC host devices can use SDXC cards if they are first reformatted to the FAT32 file system.
This is not exactly the answer but to me the compatibility seems to be very high.
Imho the torx screws have a higher quality than philips screws.
CE in pic 28 seems to be “Conformité Européenne” not China Export :wink:
On the reddit table @Coke2625 linked, one can read IP65 dust tight and water resistant.
But on the picture 42 it is written IP55 :sweat_smile:
Little note on the name… The Fairphone (Gen 6)
Is it really happening? this is it, the last one (r)? The one on which everything can be replaced?
It’s a picture from Reddit, it’s maybe not 100% true.
The Shift 8 has IP66. They used seeling lips to achieve that. Curious to see what FP has done to get better rating, if the information about the rating is correct.
The tricky part of such sealung lips is, its more or less easy to assemble the phone “wrong” to impair the IP rating.
The next model will be called “The Fairphone (Gen 7)” I guess…
very true, it could just be a bland and transparent branding move.
If it is just that, it’s not that well executed. The “The” is a bit clunky tbf. The facebook did get rid of the the ; there isn’t any reason to do that, really
Regarding the name: The brand name is spelled “fairphone” on the device, the device name (picture 39) keeps capitals: “The Fairphone (Gen. 6)”. Not sure what to make of this.
I would rather assume the picture is more difficult to alter so sadly it seems IP55 that is.
And the model name (pic 14) says FP6.
Could it be we will see more fairphones within the same generation?
Maybe we should just remember that all we have is nothing more than speculation, so we speculate about the speculation. Well nothing wrong with that just mentioning to contextualize (expectations…).
My two cents on this topic, is that with the back and battery being secured with screws, you can no longer do that party trick where you quickly take off your back cover and take out your battery to drop some jaws in the room.
Thank you for coming to my ted talk.
Some Details about Fairphone 6 have been leaked. Amongst them a release date: June 25. 09:00 MESZ
Erratum: It’s 11:00 MESZ
Psst! Nobody is supposed to know :shushing_face: .
Oh, nevermind …
That phone lools extremely good, in my opinion. I might just ditch my aging FP4 in favour of this one, should the software stack be good enough (which sadly isn’t guaranteed).
tbf, the name of the thread should reflect the evolving discourse on the matter :stuck_out_tongue:
Never heard of MEST. I thought we were using CEST from Madrid to Vienna.
I mixed up German (MESZ) and English (CEST), sorry.
Well at the moment its still what it is: a possible relaease of the FP6 on 25th June. FP itself nowhere said what they are planning to reveal at that date, its still a secret :shushing_face:
Apparently, there is already detailed specs site at gsmarena (Fairphone 6 - Full phone specifications). It appears that FP6 will be even (slightly) more gigantic than FP5, so calls for smaller/compact FP were not heard … again. Shame, until such phone, I will stick with FP5.
