Hi dear Fairphone-users!
My wifes Fairphone 2 (3.5 years old) started to act weird yesterday: First we updated it to the latest Fairphone OS-version, that worked flawlessly. Then a few hours later it rebooted randomly (She was using it while it happend - but that happened often since we upgraded to android 7 - my FP2 does that too) and got stuck in a rebootloop. I could go into recovery mode and manually reboot it, but it would just return to its loop. I took the battery out for the night. But that didn’t change anything. So figured I had to reinstall the whole OS - luckily I could make a backup before trying to make a factory reset, because after some time the recover mode started to crash…
And after some random reboots, I couldn’t access recovery mode anymore. Now it just shows the black Fairphone screen with “powered by Android” underneath it.
Next Step: Fastboot. I could and still can access fastboot. I also can manually install Fairphone OS - at least I get confirmation it has been installed - but the phone doesn’t boot it. And still: I can’t accees recovery mode. I even tried to install Ubuntu touch - just to see if I could get TWRM at least installed and working again.
So… yeah… I’m figuring it’s a hardware problem? Well at least that’s my question… did I try all software solutions? Or is there something anybody can think of to try.
I even swapped all modules from the broken phone with my still working FP2, but I figure it must be the main module then…
