I’ve read a couple of posts about the Fairphone 6 suddenly dying, and since two hours ago I’m part of the club This and a couple of other things make me wonder whether the Fairphone 6 - while the slogan is “The one that lasts” - has a quality problem. I’ve bought it about ten months ago, and I am quite diligent with my stuff, so this has never happened to me with other phones (except after 5+ years).
I noticed the following issues:
The moments switch seems to have a slightly loose contact, so when I just touch it very lightly when in the upper position, it immediately reacts as if it was in lower position. This has been around from the beginning. It didn’t bother me though, so I didn’t pay much attention to it.
About ten days ago a small crack started to show in the plastic body between the power switch and the display (see picture). I cannot recall any violent impact from the outside, so I have to assume there was some strain on the plastic that caused it to break, which would either hint at sloppy manufacturing, or material of bad quality (or both)
Today, the phone just died lying on my desk. No reaction to anything anymore
The “official” Fairphone case, while comparatively expensive and coming with not much material (I only bought it at the time because there were no alternatives on the market yet) seems to be of bad quality as well:
the matte coating wears off very quickly, especially on the corners (see pic)
Two days ago, I slid the phone into a phone holder in the car from above, so there was a bit friction on the sides of the phone. I didn’t force it into the holder though, it was an entirely normal movement. Result: The volume down button of the case came off (see pic).
While I’m not sure about the phone dying - which could be coincidence, but still shouldn’t happen after a mere ten months of use -, I get the impression that at least the quality of the plastic used isn’t great at all.
Hi @deesnook, having used BlackBerry until June this year and now switched to the FP6, I can only agree. My BBs never ever needed a case, nor did their frame get damaged so easily.
That said, I don’t have enough experience with other brands to know whether this is an FP specific issue or whether making phones more sustainable inevitably makes durability harder to achieve.
After now 5 months on my FP6, the upper part of the back makes a strange creaking noise whenever I touch it, like a creaky stair step. I end up handling my phone extra carefully when people are around, just to avoid the inevitable: “Haha, seriously, what’s that noise coming from your phone, what brand is it?”.
From skimming the forum, I’d say that sudden death is not a widespread problem.
OTOH, there are other reports of the volume button falling out. Annoying that Fairphone doesn’t sell spare parts for that, at least not on the webshop. Somebody made 3D-printer plans for a spare, but I don’t know how well that works.
My own FP6 is more than a year old by now, and I’ve not been particularly careful with it. The only hardware problem is that the plastic frame has fractured at one place, like yours did at the power button, but on the opposite side, 2 cm above the top volume button. So far, it hasn’t mattered. The frame isn’t available as a spare part either.
The materials used are not great and th case is awful. You can put the buttons back into the case if they get pulled through though, you just need to o do it from the inside.
My phone has also died intermittently, but weirdly has been better since they fixed the WiFi issue. That said, it’s less than ideal when it happens overnight and the alarm doesn’t go off…
@Lembramol I’m not so sure about your conclusions. There are a number of threads about the FP6 dying suddenly, and especially this one
has copious examples and suggests that there might be a bigger problem. If I had read it before, I probably wouldn’t have bought it despite liking the concept of Fairphone very much. Also the fact that the frame seems to be prone to break after roughly one year with normal usage belies the idea of sustainability.
If it’s completely dead, before writing it off try holding the power button for 20–30 seconds, then charging it for an hour with a known-good cable/charger and checking whether a computer detects it over USB. If it gets hot or smells, stop and unplug it. At ten months, the sudden death plus the cracked frame are worth putting in one support ticket as a warranty/repair case; the case button is a separate accessory issue, though it can usually be reseated from inside if you find it.
Thanks a lot for the suggestion! However, I won’t be able to try because I already sent the phone in for repair. I expect it to be covered by warranty. If not, Fairphone has lost a customer.
I actually tried charging it, but no reaction whatsoever, which made me assume there’s some issue with the mainboard or something like that
@all: to discuss the specific death issue, please use the existing topic to no duplicate things, and if needed discuss here the general quality question.
A phone suddenly dying is certainly a quality issue. No need to discuss it in detail here, but a sudden and complete failure without discernible reason is a major flaw. What could be worse than that? So it deserves mention also here with regard to quality
Funny, i also had an overheating problem a few months ago, “solved” by disabling GPS access to google play and some other google related services.
And now, i’m in the exact same case as you: a crack appear around the physical switch, device start rebooting randomly, and just die a few days later.
And Fairphone answer is: a damaged frame caused the problem, warranty is void. Probably my last Fairphone, i loved the concept, but my FP6 was a year old and never left it’s protective case or had any accident.
