Fairphone 6 'moments' launcher problem
Hi! Got the Fairphone gen 6 this week and all went smooth. Discovered that the ‘moments’ slider at the side activates a minimalistic launcher instead of the standard launcher of your choice.
After setting up my phone this was working excellent. But a soon as i logged in to my google account (and the play store) the launcher got flagged as harmful and now i can’t use it anymore. It is gone from the play store as well.
Tried to disable play protect but no solution.
Anybody?
Please report to FP support, SW is still a bit work in progress
Same issue with me - asking to download Moments from playstore but then it shows screen with button to click install it which I’m loathed to do because I can’t find it in a general search for Moments.
