Hello everyone. I’ve just joined the forums as I couldn’t find anything about this issue on here or online.
As a background I repair phones as a hobby. Sometimes I resell them, sometime I keep them but I figure it helps to keep devices out of landfill and I enjoy it.
I recently purchased a Fairphone 4 and a Fairphone 5. The Fairphone 4 was a simple fix, new screen and then an FRP bypass and it’s good as new.
The Fairphone 5 however is giving me issues. It was stated as having a software fault that caused it to freeze occasionally, needing a reboot. However I’m leaning towards it being a hardware fault.
I’ve been able to reproduce the issue regularly. It happened on an older FP Android 14 release it shipped with, I updated to the latest version and it happened again. I then unlocked the bootloader, wiped the device (fastboot -w) and used the manual OS install method from Fairphone. The issue still occurs. I now have LineageOS installed, rooted to see if I can capture more data about the issue. The device has rebooted once and locked up under Lineage once already.
The issue is twofold. The most often occurrence is that will just reboot itself without warning. The second seems to be when the device is sleeping. It will refuse to do anything, the screen will not turn on, no haptic feedback can be felt and it will not power on with any combination of physical button presses. The only resolution is to remove the battery.
The only log file in /data/anr I’ve been able to pull was relating to the battery state changing. Funnily enough it said battery state changed to 20%, however the device was reading 45%. According to the battery info in the official Android 14 OS the battery is 100% health with 0 cycles. Either the phone was brand new (it is in flawless condition), or could there be something wrong with the battery? Physically it looks fine.
I have fully disassembled the phone to see if there were any tell tale signs or water damage but didn’t find any. The only thing I noted was that the ribbon connecting the “Top Unit” to the main board had a strange discoloration, almost like it had been exposed to heat.
I am currently keeping the device on charge, powered on to see if the issue occurs while it has an external power source. The other thing I will try is to disconnect this ribbon to the top unit and see if the issue re-occurs.
Any other ideas? Obviously I could start replacing parts immediately but I don’t want to start throwing money at this device if it’s a lost cause.
