Fairphone 5 - 5G with Telenet
@AleMB just fyi, I have no 5G issues on Orange BE. Also didn’t need to configure anything, it was there immediately.
Thanks for sharing…I think resellers should test compatibility of their devices with the networks of the markets in which they decide to sell, before introducing them, specifying if there are limitations with some carriers. This could help in consumer purchasing decision and would have zero costs.
It costs money to test every possible smartphones for every possible carriers because you need somebody to do it (and this person does not work for free).
Are you really considering that a relative cost in the market of smartphones?
Is this already under investigation by Fairphone?
EDIT - also, I checked the major providers in .be (Orange, Telenet, Base, Proximus) and I noticed that among these, the only ones that offer Fairphone are Orange and Proximus.
The reason could be a compatibility issue (which might or might not get resolved in due time).
Yep…in the meantime I managed to get one Orange SIM; if I still won’t get 5G , then it’s my unit (considering your experience).Otherwise, it’s the compatibility with Telenet
So with Orange Belgium, 5G works perfect; final verdict: Fairphone 5 has NO compatibility with Telenet 5G at this moment. Thanks to everyone
ok. I think you should also share that with FP support (they don’t habitually read here). If you feel this has already been picked up by them, that should do (if you feel that they haven’t really accepted it as a bug I could also share it on the FP3 issue tracker for the betatesters but of course I can’t test it for you…)
Where in Belgium are you based?
Yes, I’m in contact with the support, I’m keeping them informed. I live between Mechelen and Leuven
Did you look at Couverture 5G, 4G, 3G BASE/Telenet Mobile - nPerf - nPerf.com ? Depending on where you are between Mechelen and Leuven, there is no 5G from Telenet.
Here there is Telenet 5G for sure because, as I wrote before, with the same SIM card my second phone runs 5G without issues
Sorry for not having read everything.
Since Orange and Telenet use the same bands (Belgium 5G - NR, 4G - LTE frequency spectrum bands, 3G - WCDMA, 2G - GSM, FDD, TDD, FR1, FR2 mmWave mobile networks), I am surprised it doesn’t work with Telenet if they made all they can to make it work.
No problem…maybe it’s temporary . But with Orange works perfectly
Hello all,
I used the search and found this topic:
but couldn’t respond anymore because the 3-month-limit has passed by.
Last week I got my FP5 and for a few hours 5G was available:
IMG-20240203-WA0013~2
However, after a few hours the FP5 with all updates installed switched back to 4G and since then I haven’t seen a 5G connection anymore (same location).
As suggested in the topic I mentioned before I removed the APN’s but this didn’t fix the issue.
Are there any other things I can try?
I reopend the topic and moved your post.
Maybe you can check the speed of your downloads and data connection. It can show 4G but have 5G speed connection. Then its only a icon probleme showing 4G instead of 5G
Any update on the 5g connection?
Did you get the 5G connection back since your last post?
