Fairphone 4 unlocking without oem unlocking possible?
Is ist possible to break the OEM unlock using a devinfo-unlocked.gpx file on the Fairphone 4 ?
The Fairphone 3 normaly have an unlocked critical partition and it works by flashing the partition using fastboot flash. Does something similar work on the FP4 ?
I guess if this would be an option it would have been discussed here in depth
Thanks. I will follow the linked discussion.
