Hello dear community,
I installed /e/OS on my Fairphone 4 using the Easy Installer. Everything went fine, including the USB driver update.
But after the final reboot, the phone showed a brief security warning, then went straight into fastboot mode — and now it stays stuck there on every boot.
The real problem:
It’s not detected by platform tools or Minimal ADB. I cannot do anything on the phone.
fastboot devices returns nothing
It looks like the phone is soft-bricked or something similare. Anyone seen this before? What should I do now? Appreciate any help.
Beside trying different cable, USB Ports another PC I guess the only other option is to contact support, because when you can only boot into bootloader (no recvory, no System) and you cant reach it with fastboot commands, only FP can help you to get it send in to their repair center.
Thank you for your answer. Yes after some research, the only way looks like to try to use the EDL mode to flash directly the system from the cheep with a “Qualcomm Flash Tool”. I checked, it looks like pretty advanced and not very certains. I will send it back to the repair center.
Sad that the e/os installation did not worked But I do not think I will try to install it again.
