Fairphone 4 notification vibration could not be turned off
I´m having issue turning off the vibration of the notification, I looked under settings but I do not find it anywhere. Does anybody know how to do it?
The help provided here did not help either because I do not find this settings:
Thanks,
kind regards
Jasmina
Welcome to the community :wave:
That setting is still in the same place Settings → Accessibility → Vibration & haptic strength.
You can also just search for “vibration” in the settings and it should show up.
If you have problems getting into Settings, you can reach it either through the shortcut in the app drawer or by swiping from the top two times and selecting the little gear icon:
