Is that the recommended place to shop for Fairphone products in the U.S.? Though I think they only ship with /e/OS. Can you unlock bootloader and change OS on a Murena Fairphone?
However I seem to recall that if you purchase from Murena and (re)flash FPOS, it affects your warranty. Please double check warranty conditions offered by Murena.
Yes, you can. Don’t lock the bootloader in the process.
First you have to check
`fastboot flashing get_unlock_ability_’
If the outcome is 0 then never lock the phone, because it’s not possible to unlock the bootloader again.
