As you may already know, like other networks, we are switching off 3G across the United Kingdom. We begin this switch-off from the 9th of September and expect this to be completed within two weeks. This means, if you have an incompatible device, you will not be able to make or receive calls, texts or use your data allowance. This could also impact your service whilst abroad, as many networks around the world have already stopped supporting 3G devices.
Due to a technical issue with some mobile service providers, including SMARTY, we believe that your device will NOT work with SMARTY after the 3G switch-off (please check if your device is listed [here] It may work with some other networks. We’ve checked and your device should work with Three, our parent network.
To remain connected with SMARTY, we recommend that you change to a newer device that is compatible with 4G calling and 5G and is not listed on the above list. [Our website] has information on replacement devices and we are exploring further options to help you.
We are very sorry for this, and we hope you remain with SMARTY, after upgrading your device.
If you have recently upgraded to a compatible device, that’s great! There is nothing that you need to do, and you will continue to be connected.
Looking at the list, the Fairphone is listed on incompatible devices, but it is, obviously, 4G compatible…
So is 4G calling working for you? Without this working and no 3G and 2G you will not be able to make calls. Its def capable to do 4G Calling, however when your provider says its not compatibel and they are not willing to change that it might not be working.
… which indicate you would need VoLTE (Voice over LTE = 4G calling) provisioned by your provider for your device, which they say Three would be able to do.
You probably know that Smarty is a brand name for “Hutchinson 3G” as is the “3” brand. Your phone will still work but you will find that you get less coverage than you do now. Currently where your 4G reception is poor you fail back to 3G. When 3G is switched off there be nowhere to fail back to as 3 never used 2G.
The other 3 networks (Vodafone, O2 and EE) still have 2G to fail back to as far as I’m aware.
I’m not sure about SMARTY, but I’ve had issues with 3G reception where I live. So a year ago I looked into 4G calling. I tried third-party provider Virgin mobile, but 4G calling/VoLTE didn’t work on my FP3. I asked on the beta forums a year ago and got the following response
which is fair enough. I understand that it’s not trivial to add in providers.
So I had to go with a main provider (in my case EE) which is supported and works very well for both 4G and Wi-Fi calling on my FP3. So I would guess that Three would be fine too. I’m not aware of a list of supported providers. Might be worth checking with Fairphone Support.
I’ve no idea, being as I hardly ever use the phone for calling, and when it is, it’s next to my head so I don’t know what it says on the screen, if anything.
Yes, I am facing the same problem. Looking at the FairPhone hlep page it only lists Voderphone as having VoLTE & VoWi-Fi compatibility… which isn’t a great choice! I would much rather switch to an O2 based provider, so I can keep my roaming when abroad. Anyone know if the VoLTE function works on O2?
My network provider (Smarty) has been contacting me to say that very soon, their parent provider (3) will be switching off it’s 3G networks.
Fairphone 3+ is on the list of phones that will no longer be able to make calls or texts, as it does not have the function of 4G calling.
I could switch to another provider temporarily, but all companies will be switching off their 3G networks in the coming months.
Does this make the Fairphone 3+ obsolete? All the advice I can find, both online and at phone shops, says I need to just buy a new phone with 4G calling.
Is there any way to update my current phone or make it work once the switch off happens?
I would dump Smarty and avoid any MVNO that piggybacks off of 3. Oh, I’d also ignore Lycamobile too (EE) as the Tory donor class don’t seem to want to pay their due taxes : Guardian newspaper article on HMRC winding up petition.
Off the top of my head, Tesco mobile uses O2, 1pmobile uses EE and Lebara use Vodafone. All of those still provide 2G which 3 never did. 2G will switch off by the year 2033 according to OfCom. The FP3 will be long dead by then if recent sudden deaths are anything to go by.
As mentioned above, VoLTE with FP3 works well on EE.
I think most of the MVNOs don’t offer VoLTE at the moment, but I assume they will have to as 3G turns off. Unfortunately, Fairphone will no longer implement VoLTE for additional providers on the FP3 (see above), so presumably the list of which providers the FP3 can use is now fixed.
I know this is all explained here and on OFCOM site but still very confused. I have a FP3 am with Smarty and today find I cannot send SMS. Three and Smarty say their network is up and running but I have emergency calls only.
My partner has FP3 and is on EE but CAN send SMS (they are in a different part of the country). Why is it working on EE (which OFCOM tells me switched off earlier this year) but not on Three (Smarty)?
I’m on a really cheap tariff with Smarty which I also have my kid’s phone on. I really don’t want to change to the expensive providers on the O2 network. Should I move to a provider that uses EE, even though that appears to have already switched off 3G?
Would anyone be willing to explain to me in simple words, please.
I think the issue is that the Fairphone developers have to add providers to the Fairphone 3 software for those providers to work using 4G VoLTE (i.e. voice over 4G). I think they have done that with the main providers (i.e. O2, EE, Three) but not with the virtual providers (i.e. Virgin, giffgaff, Smarty) which need adding separately (although I know giffgaff don’t support VoLTE).
When I asked Fairphone a year ago about adding new virtual providers the response was that they don’t have the resources to do that now.
Upshot is that I had to switch from giffgaff to EE (pay as you go) £10 a month bundle which includes 8 GB. Not as good as the virtual operators, but now VoLTE works.
Hi, I’m curious, because the Fairphone list of compatible providers with the FP3 does not include EE! Can you confirm FP3 on EE works with 4G Calling, and you get Caller ID working too? It looks like I might need to switch - I’m in the UK - and this is useful information.
Sorry for the slow response. I can confirm that I have an EE Pay as you go SIM (with a ‘£10 subscription pack’ mentioned above) and I have 4G/Wifi Calling and Caller ID works. I don’t think I did anything special to enable it on my FP3.
